J31Rob's First Build of 2012
The "Get The Fuck Off Your Ass & Get Loud" Build
Car: 1993 Toyota Corolla
Headunit: Eclipse CD7200mkII
Sub Amps: (2) MB Quart ONX1500.1d
Subs: (4) Sundown Audio SA10 D2s
Sub enclosure: 5.5 cubes @ 31hz
(I pulled the baffle from an old 18" box I had)
Mid/high amp: JBL PX300.4
Mids/highs: (2) 6.5" TC Sounds prototype / (2) Selenium ST350
No pictures, doorpods need finished (which I'll likely never do)
Wiring & electrical: All KnuKonceptz Kollosus Flex 1/0, Memphis 4ga, Redtop under the hood, 110aH shitter in the trunk.
No pictures, why would you GAF about this shit?
Any and all input is always welcome on my builds. IDGAF if it's negative, positive or neutral. Say whatever you want. :thumbsup:
the FUNK / facebook.com/The.Funk.765
CarTune Netwerk / facebook.com/cartune.netwerk0
Alpine / Sundown Audio / Audio Technix / Sound Solutions Audio
Here it is just thrown in on a MB Quart DSC1500.1, no big woop. Just getting a general idea of what it sounds like, yes the sub cutouts aren't centered. No big deal.
Took some videos & scores before pulling it all out to build the 4th order blow through.
Did some work this weekend.. pulled it all out to prep for the new enclosure. Got the body saw out & did some work in the rear deck to fit this new beast of a box. My poor car hates me. I'm getting new suspension in the rear to handle the added weight too. I gained close to 3" just taking it all out so I figure I probably oughta handle that.
A little testing before taking the existing setup out.. this score is w/the 4 SA10s @ 1 ohm on the Atomic 3k in ~5 cubes @ 33hz. Driver door open, mic on the dash.
Before:
Half way there:
After:
A little bit of pretty work to be done to the rear deck still.. but it'll happen when the enclosure goes in & I either glass it in or seal it off w/wood & wrap it.
Here is the new box design:
Port will be firing into the cabin of the vehicle & sealed off from the trunk.
Started on the enclosure yesterday.
Starting on the baffles:
Done:
Dry fit:
Building sealed chambers:
Back wall added:
Bottom added and sealed up:
Sub cutouts are just a tad too small, didn't think to check that before hand lol. High grit sandpaper or a small runover with a router should do the trick. Gonna wait to put the top on for ease of dropping woofers in. Its not impossible to add/remove them with the top panel on but its just gonna be 100x easier with it off.
Going to try a port with 2x2s first, then gonna play with different size aeroports with a removable front baffle. It'll be interchangable for music/SPL/whatever.
I know it's nothing spectacular or anything & I probably won't get much feedback.. but I figured I'd post the log anyway.
that deff should get down dude! very nice
1999 grand prix gt
kenwood x994 head unit
1/0 big 3 all shok industry single run to the back
New mid/highs coming not sure what
Soundqubed q2200d at .5 (have)
2 soundqubed hdc3 12s (have)
New box to be built.. sealed firing forward (yet to be designed)
200 amp alt not sure exact size or manufactor xs power batts
My car seems to peak extremely low.. so my goal is to break a 50 by summer. If I don't do it with this box.. it's on to the next. LOL. The interchangeable port should help a LOT when it comes to metering, however. Gonna be able to try different aero port configurations, slots, whatever I want really. I've got some 10" I'm itching to use.. but haven't crunched the numbers yet to see if it'll work.
The lines represent where the panel will be mounted on the front of the box, the red smudges represent the panels the t nuts will be sunk into along with utilizing the 3/4" lip from the top & bottom panel for a good seal.
I'll just seal the trunk off BEHIND the dummy panel so that it doesn't "unseal" the trunk per-say when I swap panels.
Kind of a jank drawing but I'm sure you get the general idea.
That 4th order will fit in the trunk, right?? Looks fucking huge! But it should get pretty gnarly once you get it playing!
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
I did a TON of cutting to fit it. I had cut once before to fit the last enclosure which was ~6.2 before any displacements. This one is ~8 before displacements. The walls & woofers drop it to about 6. When I do aeros in my dummy baffle it will drop the ported lower.. but that is all a part of the grand scheme.
  • Who's Online   0 Members, 0 Anonymous, 3237 Guests (See full list)
