Its been awhile since I've messed with installing a crossover. But my question is how do I install a 4 channel amp for the midrange/ mid bass and another 2 channel for my highs/tweets to a 3 way crossover without having to purchase a 2nd crossover? The 3rd amp is my sub amp
Edited by speedball1978
got a link to it? If it is 3 way active then you just connect the RCA outputs for tweets to one amp, then the RCA outputs for mid range and mid bass to the 4 channel amp.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
it may be easier to get a different crossover, but it could be done with that one. i don't know much about the crossover on the DC pai amps, what settings does it have?
F150:
Stock :(
Processor: DSR1
sure it will. you can set the LP filter on the amps to say, 300hz on the amp and the HP settings on the crossover to 70hz. That gives you a band pass of 70-300hz for midbass.
Then do the same with midrange, just change the settings for 300 HP and 3k LP to give you mid range bandpass
you can use both crossovers together. However, I don't know what settings the DC amp has so you may not have the range to do it.
F150:
Stock :(
Processor: DSR1
