RD Audio D9 @ .5 OHM
CJSmith
I'd bet the amp goes first
On a D9? That amp will run for DAYS at .5 ohm.
And to the OP, yes they will handle that power.
have you ran a d9 at .5 for daily ripping on it full tilt?
Me personally, no, I do just so happen to have an RD D9 now for another project, but I know several people who have them, and I have setup oscoped this amp on a few different competitors vehicles so I know what it can and can't do. Also doesn't hurt I am good friends with the current owners.
i was just asking, i have seen them in the lanes be EXTREMELY successful at .5, sometimes lower, but all were burps. not daily. :shrug: OP it's all about application.
I have a teammate that ran his daily at .5 ohm for months in a trunk car on two warden 12s, doing 150s. He blew his actually because it was in trunk on a 115 degree day and dropped voltage down to about 10 volts, smoked it. But no doubt would have been fine if voltage was up and didn't have the heat in a trunk.
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
My D9 is in well ventilated area, and never sees under 14v. and 50% of the time, I'm doing burps between 40-55hz.... I just wasn't sure if those subs could take that much power. I know they're very high quality, but I've never personally ran them until now and was just trying to get some opinions.
*Rebuid in progress*
I'm pushing 4400 watts to each of my mayhems daily yes they can handle it and want more...:-)
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Double post fail...anyways don't clip the amp trying to get the most power out of amp...keep your voltage up...an u will be fine
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
[/quo
My amp is about 75% of the way up, so they're getting about 2700 RMS each, so I should be good then. lol.. Thanks for the help.
I would up my signal input voltage if you are going to be running the amp at .5 ohm. so you don't have to run your amp at 75% gain. Just me though, I like being able to keep my gain as low as possible.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
I'd do the same but not through a line driver, if your headunit has 2v preouts try getting a headunit with 4 or 5v preouts, I'm not sure about this amp but most amps don't like being line driven.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
Are you talking about running higher voltage to it, so it can put out the same power without having the gain as high? :shrug:
  • Who's Online   0 Members, 0 Anonymous, 1068 Guests (See full list)
