Orion hcca 15" enclosure help!!
88trooper
S10's are sub up or forward, port sideways.
I better not find out you are charging for boxes guys.
2nd time ive seen it tonight.
I actually suggested port up, and I'm the one with the S10. Thanks though.
Here is the suggestion. See if the dims I used are adequate, box is port up / sub up:
Enclosure Specifications:
Fb = 32.029 Hz
Vb = 3.651 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 20 in
External Width = 32.75 in
External Depth = 18 in
Port Width = 3 1/2 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 32 3/4 x 18
Left & Right Sides = 16 1/2 x 17 3/4
Front & Back = 32 3/4 x 17 3/4
L Port Internal Assembly Parts:
Front to Back = 14 1/4 x 16 1/2
Extension = 13 1/2 x 16 1/2
Bracing is recommended, may update later the design to add bracing displacement once you know this fits.
Let me know any questions.
I'm going to be doing a double thickness baffle for the sub so you might have to factor that in.
The double baffle is already considered, notice the line:
Fb = 32.029 Hz
Vb = 3.651 ft^3
Cut List:
Sounds good man, thats about perfect. I'll send you a PM, I have a few questions.
Fb = 32.029 Hz
Vb = 3.651 ft^3
Cut List:
How are you getting these dimensions? Im putting these exact measurements in a Speaker Box Tuning Calc program and getting 3.89 cubic feet tuned at 34
  • Who's Online   0 Members, 0 Anonymous, 1315 Guests (See full list)
