Ahh.
Not enough for f3 around 25
Need around 1 each
Even with the polyfill? What about port area? Think I gave it enough?
Also can you explain how to find the F3? You can message me if you'd like
Johns.jpgSuburban Coming Soon
Polyfil does not lower the f3.
Actually raises tuning in a bp
Really busy today.
Ill come back on tonight and answer.
i might chime in later and gain some knowledge too :popcorn: i might do this same thing with some LVL4s if i cant fit a third one. I also am not too sure how to go about getting the tuning correct with the port. Looking to do upper 20s into the 50hz range if i did it..
06 Jeep Grand Cherokee
2 DC Level4 12"
Soundstream TA1.3000d
4 RF Punch 6.5" Components
2 RF Punch 3.5" 2-ways
RF Prime 400.4D
XS Power XP950 +&-run of XScorpion 1/0 OFC My Civic Build
Im just looking for low 20's to about 55 and im good after that.. looks like I need to pull the top off and remove all the polyfill lol darn. I might move my port out too and it'll raise my tunning but if the polyfill is actually doing the opposite of what I thought it would changing the tunning wont do much affect my port area and possibly make it more effiecnt and my subs need more power for the mid 30 range...darn
Poly fill is only affecting by 1 hz
Its the other things it deos is why i use it.
Ive had these same subs but in 15". 4 of them and we had a 1:3 ratio and it was retarded low and would still maintain high frequencies, it peaked at 27hz @ a 153.4db sealed on dash, there was only 4k on it.
Try changing up the ratio i would say
Bassaholics Audio
Custom Enclosure Designs
Custom Built Subwoofers tailored to specific enclosures
For more info
Email: [email protected]
Hmmm ok ill wait for you to get not busy so I can learn :) and I was thinking that having the port that close to the subs is affecting loading which is why I was going to put it full outside the box
