Box design for 4 10's
double post
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
Ok, the angles are 40, 100, 40, However I might change them. If you can measure the magnet diameter(s) and post them that would help make certain the sidewall is far enough.
Edit: to complement the answer the 100 deg angle gets shared to 50 deg to each board.
thats what i thought. and the length from the bottom of the magnet to where the sub sits when being mounted is 6 1/4 inches.
Car
1999 Dodge Stratus 2.5L V6
Deck
Kenwood DDX-512 Head Unit
Doors
(2) Diamond Audio DA6.6 6.5's
(2) Cerwin Vega 3" Horn Tweeters
(1) Alpine MRP-F240 for Doors & Tweets
Rear Deck(on factory wiring)
(2) JVC 6.5's
(2) Rockford Fosgate 6x9's
Subs firing forward
(2) Skar Audio VVX-12's
(1) MBQuart ONX1500.1D for Subs
Wiring
Cadence 4AWG for MBQuart Amp
Advance Auto 8 AWG for Alpine Amp
Cadence and Monster 4 AWG Wire to Kinetic HC1200
Batteries
Stock Replacement up front
Kinetic HC1200 in the back for the amps.
And yes "I drive a Dodge Stratus"
Here is my build log:
http://www.stevemead...__fromsearch__1
Ok so I had to figure out the dims of the subs and I had to chsnge the depth among other changes to make everything fit:
A couple of MDF rings are necessary.
if i added rings to the previous design would that work too. because i really liked the dmesnions of the other box. didnt take up too much space in my trunk.but f it has to change to work i can give up the extra space.
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
If you add rings on the center subs those will hit each other, if you make the box less deep the magnets of the centers subs will hit the back wall.. I can't see other way.. if you have a better idea let me know..
does that change the length of the boards that make the "V" ?
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
No it does not, same as before, the changes are:
1) rings on the outer subs.
2) the locations of the subs.
3) the depth of the box.
4) some bracing that I have yet to show you.
what kind of bracing. front to back? side to side?
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
This is getting kinda complicated. Could i still get good sound if I Did a rectangle box and did 4 10s facing up? And would ported or sealed begetter for that design? And anyone that can give a sketch up would be much appreciated.
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
  • Who's Online   1 Member, 0 Anonymous, 1118 Guests (See full list)
