Box design for 4 10's
It's going real well. Use lots of screws..and nevermind you made good progress, don't rush things, you will have that box for a while, so better get it right than fast.
I was wondering how do I calculate where to cut the holes. Since you have them one high and one low I was wondering if you had any exact location or just kinda guess a spot in the middle?
Hope this is clear enough, the measurements define the center of the holes, the baffle has mirrored horizontal dims:
Hope this is clear enough, the measitements define the center of the holes, the onther bffle has mirrored horizontal dims:
thats perfect. thanks again. more pics tomorrow
Car
1999 Dodge Stratus 2.5L V6
Deck
Kenwood DDX-512 Head Unit
Doors
(2) Diamond Audio DA6.6 6.5's
(2) Cerwin Vega 3" Horn Tweeters
(1) Alpine MRP-F240 for Doors & Tweets
Rear Deck(on factory wiring)
(2) JVC 6.5's
(2) Rockford Fosgate 6x9's
Subs firing forward
(2) Skar Audio VVX-12's
(1) MBQuart ONX1500.1D for Subs
Wiring
Cadence 4AWG for MBQuart Amp
Advance Auto 8 AWG for Alpine Amp
Cadence and Monster 4 AWG Wire to Kinetic HC1200
Batteries
Stock Replacement up front
Kinetic HC1200 in the back for the amps.
And yes "I drive a Dodge Stratus"
Here is my build log:
http://www.stevemead...__fromsearch__1
Well I took some pictures but my computer is messing up so I am posting this from my iPad. I decide to do a test fit with just the back a sides on and well it doesn't fit. Only off by Iike 3 inches. But instead of taking off the sides an shortening it I decided to cut it in half. From the start I wanted two boxes so I could guarantee it would fit. So by cutting it in half I only add 1 1/2 inches so it will fit almost perfect. So that's where I'm at. Will hopefully get the pics up tomorrow. Just wondering, How will this effect box volume???
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
WOW! well If you did what I think you did probably will not be a big difference, when I take a look I will let you know what I expect, I am surprised that it was off by as much as 3 inches, that's a lot. Bear in mind that the 40 deg angle is critical for the subs to fit.
ohhh boy...
i hate the mentality "cut first, ask how it changes things later" it's just freaking counter productive.
also, next time measure twice, cut once. lol
post pics of what you did
More box builds
I'm with captain stupid.
ohhh boy...
More box builds
ok i got the pics to upload today. i pretty much cut it right in half. just added a end piece and made sure it was air tight. got one side done today and will hopefully finish the other side monday. and it was good measurements from "Joe X" but i didnt thnk about the trunk opening being that much smaller than my actual trunk dimensions. i actually thought the opening was bigger than my actual trunk dimensions. but i guess i was wrong.
here we go:
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
Any thoughts???
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
Well, not sure that the subs will fit the way you placed the holes, if they do then you are good to go.
Yeah they fit. I do need to do the ring for tHe outer sub though
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
  • Who's Online   1 Member, 0 Anonymous, 1747 Guests (See full list)
