Box design for 4 10's
The subs are 6 3/8 , I suggest measuring the magnets since they dont give detailed dimensions and draw yourself something, if you found an issue I will fix it.
do you know the length of the pieces that make the "V" ?
Car
1999 Dodge Stratus 2.5L V6
Deck
Kenwood DDX-512 Head Unit
Doors
(2) Diamond Audio DA6.6 6.5's
(2) Cerwin Vega 3" Horn Tweeters
(1) Alpine MRP-F240 for Doors & Tweets
Rear Deck(on factory wiring)
(2) JVC 6.5's
(2) Rockford Fosgate 6x9's
Subs firing forward
(2) Skar Audio VVX-12's
(1) MBQuart ONX1500.1D for Subs
Wiring
Cadence 4AWG for MBQuart Amp
Advance Auto 8 AWG for Alpine Amp
Cadence and Monster 4 AWG Wire to Kinetic HC1200
Batteries
Stock Replacement up front
Kinetic HC1200 in the back for the amps.
And yes "I drive a Dodge Stratus"
Here is my build log:
http://www.stevemead...__fromsearch__1
It's 22 9/16
Ok. Thanks a lot for all the help. I will post pics when I get it built.
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
It's 22 9/16
how do I find the angle of the corner to cut the woofd to make it flush against the sides.
these angles so the wood pieces can be flush against each other.
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
All I wanna say is GREAT JOB to everybody taking the time to help this guy out, all the sketch up models and resposes are the reason why this site is such a great one!!!!
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) 6 in ports thru the rear deck
(2) T165.2
(2) T169.3
so true. coming from a newb to box building and someone who knows a little bit about sound systems i can honestly say every time i get on ths site (at least once a day) i learn something new. thanks for all the help again.
Car
Deck
Doors
(2) JVC 6.5's
Subs firing forward
Wiring
Batteries
Ok, the angles are 40, 100, 40, However I might change them. If you can measure the magnet diameter(s) and post them that would help make certain the sidewall is far enough.
make a single power "v" or a double "v"or"w"
i have seen a few power v/w boxes that crushed...
power V is the term i heard used for that style of box..but that was also in an extended cab S10 with 8 15s and 4 USamps surfboards in 2 seperate Vs...lol
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
  • Who's Online   0 Members, 0 Anonymous, 1040 Guests (See full list)
