96 s10 cadence audio build
Nice work on the box. The spacers you used for the amp look sweet too. Can't wait to see the paint laid down.
thanks. i cant wait for paint to be laid down either but still in the process of deciding a paint scheme lol. as far as the spacers for the amp, i liked them too but i will have to find others to work since they arent as tall as i need for the wires to run inbetween the amp and plexi.
audio setup
HU: sony
Amps: cadence csa5000.1(running at 1 ohm 1200w x 1)
Subs: pair of cadence s2w8-s2
Doors: cadence zrs65k's component set
Box: customed glassed box tuned @ 35 hz with one 4" port....built by me
Underhood: powerbastards.com H/O 200 amp alt, big 3 upgrade(4 awg) and optima red top battery
Wiring: SQ audio 0 awg amp kit
Cadence Sponsored
build
http://www.stevemeadedesigns.com/board/topic/133648-96-s10-cadence-audio-build/page__hl__cadence
test fitted the placement of the plexi and the spacers i got.... gives you an idea of how the amp rack with flow.
then the spacer comparison for inbetween the amp and plexi.... i may have to look for something alittle wider.
audio setup
HU: sony
Cadence Sponsored
build
explains itself....
audio setup
HU: sony
Cadence Sponsored
build
not much done but its sumthing..... :thumbup:
not that it is mounted i get to take it back off and wetsand the box some more as well as get the port hole cut out before laying some primer down.... trying to wrap this thing up but slow process lol.
audio setup
HU: sony
Cadence Sponsored
build
well i wetsanded with 320 then 800 then primed this beast. i got 3 coats on it and then noticed a few areas that need some spot potty, so taking care of those spots and then will wet sand the box with 400 then 800 and start the priming process again.
oh and hopefully will have the port in to fill this big a$$ hole lol
audio setup
HU: sony
Cadence Sponsored
build
did alittle work today not much just wet sanded with 800 then 2000.... going to lay down at least 2 more layers of primer and then repeat wetsanding process then its ready for base.
after i get the next 2 coats of primer on there i am going to get the port mounted as well i work on my "wire tunnel"
and quick shot of the port going in.....
audio setup
HU: sony
Cadence Sponsored
build
nice bro! how did u find the volume of that thing
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
  • Who's Online   0 Members, 0 Anonymous, 1882 Guests (See full list)
