84 K10 Pick Up Sub Ideas
So I got a 1984 Chevy pick up. I'm working with limited space behind the seat (don't know the exact amount of space yet) and i don't wanna eliminate the center seat for a console type enclosure. I'm lookin for immaculate sound quality (rock and rap) and still have that deep BOOM (rap). My thought is 2 Sundown SD-2 10s. Its mounting depth is only 4 7/8 inch but they have no recommendations for a box. I'm also not sure if i would go with ported or sealed. I've looked at shallow mount subs but I don't think I can get what I'm lookin for out of the shallows.
I'll get the specs for the space behind the seat soon but until i get that, what would you guys do if it was ur system.
Thanks in advance.
I'm guesstimating about 55" side to side and about 8" in depth with the seat forward 1 notch. I'm thinking of running the hifonics 1500 mono (1500watts 1 ohm). Subs are 500 rms a piece. I can wire the dual 2 ohm subs to 1 ohm right? or is that the dual 4 ohm?
You can do a nice build like one of my friends 4 8' firing down and the ports up. 4 sa 8s Would be such a clean idea on like a saz 1200 wired down to .5 ohms. you'll have the cone area with out firing into the back of your seats.
91' CRX Si
HU - Alpine cda-7995
All stock interior
Amp - Crescendo bc3500
Subs - 4 sa 10 d1 spl's
Batt - 3 x 100 ah
149.5 Street beat
Integra Build Log
Here's you a video showing a explanation of wiring.
91' CRX Si
All stock interior
Batt - 3 x 100 ah
149.5 Street beat
Integra Build Log
That'd be nice but I don't think i'd have enough surface at the bottom of the box. It'd only be at the most 8 to 9" at the bottom of the box... and i've never heard any 8" subs of any kind for that matter live. You think they'd get the job done?
Those SA-8s will do more than get the job done.
Current setup in my 96 Hoe
Hu - Pioneer DEH-80prs.
Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets)
Batts - 4 91ah rear batts, 50ah batt up front.
Subs - 2 Crossfire XSv2 18's
Alt - Singer 330A
Front stage - Random JL & Eclipse mids, Eclipse tweets
the 8s will sounds sweet in there, the best thing is ppl wont be expecting lots from 8s. till you crank that thing up. 8's sound like a good fit
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
  • Who's Online   0 Members, 0 Anonymous, 406 Guests (See full list)
