slot port help
gaitan1977
what sub(s) you going to be using? and for future reference (dont mean this mean) when you build an enclosure its usually better to plan the box as a whole first (port, sub placement, etc) usually yields better results, the only exception is have seen many people build a shell for a wall the biggest they can get and go from there which usually work out rather well but for this situation prior planning would be beneficiary
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
Many use torres box calculator. Handy tool you should download and then you can figure out what works for you.
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Well you should never do a cubic box, if it's already done you would have around 2.5 cubic feet of interbal volume, enough for a 12 inch subwoofer, take a look at a design like that:
Enclosure Specifications:
Fb = 32.279 Hz
Vb = 2.549 ft^3
Subwoofer Mounting = Front Mounted
External Height = 20 in
External Width = 20 in
External Depth = 20 in
Port Width = 2 1/16 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 20 x 20
Left & Right Sides = 18 1/2 x 18 1/2
Top & Bottom = 20 x 18 1/2
L Port Internal Assembly Parts:
Front to Back = 16 7/16 x 18 1/2
Extension = 12 9/16 x 18 1/2
  • Who's Online   1 Member, 0 Anonymous, 1417 Guests (See full list)
