Waldo129 Posted February 9, 2012 Report Posted February 9, 2012 Well im currently in the process of building a box for my BTL 18. This is what ive come up with for a design... As you can see ill be using 2 aero ports and the external port lenght would be 12 inches, meaning the ports will be sticking outside the box 12 inches... Which I just figured out will NOT work, being that it will hit the roof of my car... So I simply changed the value of external port lenght to 0 meaning all my port would be in the box. Here is what I came up with... I had 32hz at 6.33 cubic feet and now with the ports being inside it changed it to 33hz at 5.92 cubic feet. I'm sure the tuning wouldnt be much of a audible difference, im sure it will still slam the lows, but the problem is the cubic feet required. I know it would be bare minumum if not lower. My question is that does anyone think it will sound like shit because of the small changes? Ive been working on the box for 3 days and I just don't want to get it finished and then figuing out I just wasted my time. If anyone could help me that would be awesome! Thanks and check out my build, links in my signature. 02 Civic Si Stock Alt Kicker 0 gauge wire Shuriken SK-BT80 Battery JL Audio J2 320.4 Planet Audio BB 2400.1 Fi BTL 18 ufo motor My 02 Si Build! http://www.stevemead...__fromsearch__1
Sergeant_Skyrim Posted February 9, 2012 Report Posted February 9, 2012 With the port going into the box all 17 inches, you're going to have to bend it somehow. So you could just extend it out another couple inches which would increase your net volume anyways. Build in progress
Watch the bass Posted February 9, 2012 Report Posted February 9, 2012 If the box is a little bit to small for a sub, there we know a old household remedy, its called "in the abundance of water, the fool is thirsty" Bob Marley
Waldo129 Posted February 9, 2012 Author Report Posted February 9, 2012 Yeah ill let them stick out as much as I can. But it turns out to be around 6 cubes is that fine? 02 Civic Si Stock Alt Kicker 0 gauge wire Shuriken SK-BT80 Battery JL Audio J2 320.4 Planet Audio BB 2400.1 Fi BTL 18 ufo motor My 02 Si Build! http://www.stevemead...__fromsearch__1
