If you were to go Sundown what would you run? Also 30Hz is good to run for a daily driver? I thought I could just turn the gain down on the amps and be alright. Thanks again for all the help.
what aqsub said. sa's are pretty tough, but 12k to 4 might be a little much. i know a guy running 8 of them, and he is running two 3500's to them. maybe start with one 3500, and then once you upgrade subs, add another 3500, or then go with a 12k.
2001 chevy cavalier
Rebuild in progress
what happens when your CD player skips and you accidentally drop a 22 hz sine bomb at an unholy volume on 7-8 year old subs? Mechanical failure floppy sub knockage on at least 2.
well...as i see the level 6 is compared to a lamborghini.....but a corvette?
i was thinking more like a chevy volt. its cute and new and "hip", but i would just rather stick my dick in a blender.........
took the words right outta my mouth..its better to start smaller and work your way up
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
wiring down to 1ohm would be your best option for getting the most power. 3500@1ohm/4=875, which would be about perfect for your first build, even though the sa's are a tad underrated.
2001 chevy cavalier
Rebuild in progress
Do you have the subs already? If not get them to where you can run one ohm, Redbaron has some 4500s for 900 shipped i believe, You will be satisfied with this system for sure. But make sure you get the amp scoped or use a DD1, With that power + clipping is not a good combo..
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
2001 chevy cavalier
Rebuild in progress
Thanks for all the help guys, I'll be ordering subs Fri, and an amp as soon as refund gets here. SAZ-3500 and 4 SA-15's it is! Thanks again for all the imput. You left coast guys are alright with me.
