Amart88 Posted February 10, 2012 Report Posted February 10, 2012 kind of a Noob question but here it goes... On my old system i had 2 alpine type-r 15' dual 2 ohm hooked up to my BRZ2100.1D but because they were wired in series to 2 ohms, I only had one positive speaker wire and one negative wire into the amp, which actually has 2 neg and 2 pos outs but i was only using one of each. My question now is I'm wiring this amp to one ohm on a single fi btl dual 2 ohm. So can I use all 4 speaker outs, one wire to each terminal on the btl, neg to neg and pos to pos (4 total) or will i just use 2 again with a jumper?... sorry probably stupid question but i want to make sure before hand. thanks My 2005 s10 blazer build. 4 zcon 18's walled.
Amart88 Posted February 10, 2012 Author Report Posted February 10, 2012 Nvm i think i fugued it out... i feel stupid now My 2005 s10 blazer build. 4 zcon 18's walled.
08tahoe Posted February 10, 2012 Report Posted February 10, 2012 That's a monoblock amp it has 2 pos and 2 neg but its just one channel. So you can run 4 wires like you said and that would wire to 1 ohm.
