Amp is on, but subs don't play?
I just re checked that. Do you think I should pull the subs out of the box to see if something came loose? Everything checks out but my buddy was the one to re-hook up everything so I'm just on the search for the culprit. lol Thanks for all the feed back guys.
2001 Nissan Frontier3/5 drop
''Gutted"
Underconstruction
If you don't let your unborn swim in her mouth someone else will.
@ CarsHateMe, I've never heard of doing that in my life but I'm going to try that now. I'll be back in a min.
''Gutted"
Underconstruction
You would be surprised at what can happen when you change one little thing. Lol. You can test the subs without removing them from the enclosure. Use a 9v battery or a dmm. Just check the resistance if using the dmm
I was going to say to check them but you said you checked the wires. All it takes is one wire to be disconnected and its a closed circuit.
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
I think I'm bout to hit up my local Audio store, cause I can't find anything wrong. :unsure:
''Gutted"
Underconstruction
Amp works, buzzes slightly. subs work. So It's something wrong with his install. But thanks for all the help.
''Gutted"
Underconstruction
Buzzing....that's a faulty RCA cable.
ditto on rcas
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
Your right and wrong in the same sense. We put new Rca cables in it same thing, so we check the amps rca input and when we moved it around it would stop so we pushes it rca input all the way forward and it clicked into place correctly. Now its doing just fine, but thanks for all the help guys.
''Gutted"
Underconstruction
  • Who's Online   0 Members, 0 Anonymous, 1426 Guests (See full list)
