(REBUILD) 10 sundown e-10's from 2 AQ 18s Walled
Like that pillar and how you are learning from your mistakes and posting them keep it up don't listen to people trying to put you do. Just listen to the good and keep learning.
XS Power D5100, 2 D2700s, & 2 D975s
MechMan 220a Alt
DC 5K
Kicker 650.4
2 12 Ascendant Audio Mayhem's
Pioneer DEH-P7200HD
Rockford Fosgate 3sity.1
Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899
https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
Well i finally got a day off to work on my rear doors i hope they end up looking pretty good, ive looked at peoples door builds and still didnt really understand every step so bare with me lmao and these doors are pretty much for looks and practice so im doing the rear doors first since they wont bee seen as much
Started with 4 6 1/2s
Then decided 5 looked better
Used speaker grill cloth to wrap them in before glassing
Test fitting
2000 stratus10 SunDown E-10s
Singer 250amp Alt
Xs Power D975Concept c2400All 0 gauge wire10 6 1/2's in Rear Doors
glassing i see alot of painfull sanding comming up :/
Then a quick test fit, looks pretty good
Then some more layers
Singer 250amp Alt
Couple things I've got. First, way to jump in and go for it. You're learning, it's a process!
Next, on the sub/subs, to fix em, cut out another sub ring. Make it a 3" wide ring, so you can mount the subs, and also mount the rings to the baffle. Use cardboard if you need to so you can get a good cutout for a template.
The doors. Am I missing it, or how do you plan to open the doors? I don't see any handles anymore.
Like I said, learning is a process. Keep it up! :good:
are you just planning to open the doors at shows or whatever cuz with a wall it should be sealed off from the b pillar forward so u wont hear them when u are driving. well u might hear them
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
They are rear doors so i dont have to open them frin the inside and yea theyre pretty much for looks and practicr for the front doors
Singer 250amp Alt
Got another day off so i got to work on my doors more, theyre looking soo much better than i thought they would, im proud of myself lmao
More test fitting again just to make sure they still fit
first coat of primer
Singer 250amp Alt
Wow i finished these and im so proud of myself and how they look i didnt really expect them to look this good my first attempt
Test fitting
Then finally in the car
Singer 250amp Alt
More pichurz!
And IIRC Ray has a thread here showing how he glasses stuff like this and he adds the mat on the inside of the enclosure (I.E. the underside of the doors) VS the outside. That way you have a lot less sanding to do. Either way it looks awesome so far.
But I am curious about them door handles, lol.
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
The car is walled off so why would i need handles on the inside of the rear doors? Lol and i did glass the back side of the panels with mat instead of cloth, i bought a decent sander and a good cutting bit for my dremel and it was alot easier than i expected but im gonna wait and save up for my alternator before i start on the front doors but thanks bro! Im slowly getting better
Singer 250amp Alt
