Amp won't turn on
battlewalrus
I hooked up my new amp to see if it worked yesterday and it wouldn't turn on, so I metered the power wire and it was sitting at 14.4 volts to the ground and then I metered the remote wire and that was at 13.9 volts so I don't know why the amp isn't coming on.
The only thing I didn't check is the RCAs and I don't know how to check them.
It's a Hifonics BRZ1700.1D brand new
It turned on when I unplugged the left RCA for a second and then turned back off
2005 Honda CR-V
AQ HDC315-A
Hifonics BRZ1700.1D .5 Ohm
4.4 ft^3 box
Kenwood Deck
Big 3
XS Power D5100R Starter, D975 Rear
RCA's should not affect power to the amp. Have you tried hooking another amp up with the same wires and see what happens?
Edited by IBleedMusick
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
Does the power light come on. If not you have a bad amp. Only have power connected no speakers and rca and see if it powers on. You may have a short in your speaker wires and making it protect right away.
91' CRX Si
HU - Alpine cda-7995
All stock interior
Amp - Crescendo bc3500
Subs - 4 sa 10 d1 spl's
Batt - 3 x 100 ah
149.5 Street beat
Integra Build Log
try jumping the remote and b+
this wont do anything since he's getting 14v on both already.
is your amp ground in a good location/prepped well? where is it bolted to? if everything on the power connection side of the amp is good then the amp may be messed up :\
Edited by Kranny
I think it might be a ground problem because it turned on when I was moving everything around and the ground may have shifted and got a good connection to the chassis
I'm not building for a while anyway but it'd be nice to get everything sorted out before lol
2005 Honda CR-V
AQ HDC315-A
4.4 ft^3 box
Kenwood Deck
Big 3
Sounds like it was grounding thru the rcas.
Hope that wasnt a pioneer deck hooked to it.
It's a kenwood, and what do you mean grounding through the RCAs? Never heard of that before, please elaborate (obviously I know what it would be, but why)
Edited by battlewalrus
2005 Honda CR-V
AQ HDC315-A
4.4 ft^3 box
Kenwood Deck
Big 3
If you dont have a ground it will use the rca shield as a ground.
Bad shit
  • Who's Online   0 Members, 0 Anonymous, 984 Guests (See full list)
