If you dont have a ground it will use the rca shield as a ground.
Bad shit
Does it mess the amp up or only the head unit?
2005 Honda CR-V
AQ HDC315-A
Hifonics BRZ1700.1D .5 Ohm
4.4 ft^3 box
Kenwood Deck
Big 3
XS Power D5100R Starter, D975 Rear
Typically just the deck.
But only pioneers.
Just fix your gronud
But only pioneers.
Alright
14v going from the power to ground doesn't necessarily mean a good ground right
2005 Honda CR-V
AQ HDC315-A
4.4 ft^3 box
Kenwood Deck
Big 3
What ground?
At the amp?
And no, it doesnt.
Need to do a ohm check between amp ground terminal and sheet metal of the car.
That should read 0.00 ohms. Not like 80 ohms. Lol
u have a multi meter?
yeah
put either of the probes on your ground, then put the other to bare metal(no paint), set your DMM to ohms (20 or so) and see what it reads, anything more then .04 is no good? idr, >>>>that .04 might be for parasitic drain and on millivolts <<<<<dis regaurd that OP lol talking to my self
Edited by Freshman6969
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
