Orionstang new mustang trunk.
I keep looking at this thread, very informative. Amazing craftsmanship, good job! I put the floor in mine today, was mocking up side panels with 3/4" and it wasn't working out too well... definitely going to try some thinner stuff now.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
If you want 3/4" panels just do the mock up with thin stuff then transfer to 3/4
I typically go
Cardboard
1/4" mdf
Then 3/4
The 1/4" is to be able to copy to the 3/4 with a flush trim bit
Thanks for the tips. Dont want it 3/4 thats just all i had. I bought 5 mil plywood today. Just cut the piss out of my finger tho so im about to call it quits for the day. The way this cars trunk mounts are makes it so much harder than it needs to be.
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
HIs stang is the same way.
Ray could you provide a link to your thread with a DIY.
I also want to know how you carpeted it if you don't mind sharing your secrets. Your work is CLEAN!
Ive done a thread about how to.
Typically i use 2way tape and small hidden L brackets. Alot of it is pressure fit though.
If you make all the panel a great fit when in the cardboard stage
Then after you carpet it they will press into place.
Real glad you like it ken.
Did the velcro trick work out?
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
