what are your space dimentions available??
Head Unit -- Alpine CDA-9887
Mids and highs -- 2 Crescendo PWX-8's
4 Crescendo PWX-6's
4 Crescendo FT-1 Super tweeters
Mids and Highs amps -- 2 Alpine V12 MRV-F545
Subs -- TBD
Sub amp -- Crescendo Bass Cleff BC2000.
Sub Box -- Ported box 9 cubic foot tuned to 37hz for 2 15 with 140 inch port area
Processor - Alpine imprint
build your box like this you wont be dissapointed
you should build a slot ported box with the sub on the top and the port facing the trunk lid of the car.
i personally think you should run the sub at 3.5 cubes net volume, the sub will sounds a little deeper with more volume.
and the box you had thought up didnt have nearly enough port area with the SRx having an 18mm xmax you need at least 65 square inches of port area with a slot port so you dont have all of the port noise. so if i were you and your not limited here is box specs
Port Type: Slot Port Port Tuning: 33 Hz Port Dimensions: 16 x 4.125 x 38" long Port area: 66 square inches Number of Ports: 1 Net Internal Volume: 3.5 cubic feet Port Volume: 1.6419 cubic feet (includes displacement of port materials) Subwoofer Displacement: 0.1600 cubic feet per subwoofer Total Internal Volume: 5.3019 cubic feet ($40.60 extra)
Box Dimensions:
30.125" (w) x 22.25" (d) x 17.5" (h)
if you build your box to these specs i think you will be very pleased with the out come
4 Crescendo PWX-6's
Subs -- TBD
actually theres a site that sells boxes that you give your own measure ments and stuff and they build you a box that your supposed to but but after you put in all your information they give you the options to get the plans so ill sent you a link to the custom one i explaned and it will tell you the exact size for each piece its really cool
okay here is your box
this is the link for the specs http://www.klausaudio.com/subwoofer-boxes/customize_preview.php?boxid=46987
and here is the link for the build plans http://www.klausaudio.com/subwoofer-boxes/subwoofer-box-design.php?boxid=46987
4 Crescendo PWX-6's
Subs -- TBD
oh thats cool man still in high school?
im only 19 i just graduated and im working on my new system two 12's in a single cab in a 5 cubic foot shared center consol/enclosure that is ported to 33 hz
4 Crescendo PWX-6's
Subs -- TBD
So I decided to build a box for a RE audio SRX 15. I picked up my mdf today and Ready to start tomorrow. I've already Crunched my numbers in a box calculator but I'd like to put it up here and get some advice Incase I've made some sort of catastrophic mistake or something hahha.
http://gyazo.com/45a....png?1329114618
Ok, on your dimensions I came up with this 3cuft@34Hz slot ported design:
Enclosure Specifications:
Fb = 34.074 Hz
Vb = 3.041 ft^3
Subwoofer Mounting = Front Mounted
External Height = 17 in
External Width = 30 in
External Depth = 17 in
Port Width = 2 3/4 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 26 1/2 x 15 1/2
Back = 30 x 15 1/2
Left & Right Sides:
Side 1 = 15 1/2 x 15 1/2
Side 2 = 16 1/4 x 15 1/2
Top & Bottom = 30 x 17
L Port Internal Assembly Parts:
Front to Back = 12 3/4 x 15 1/2
Extension = 8 3/4 x 15 1/2
It assembles like this:
The main issue with the calculations you had was the port area, and therefore the port volume.
  • Who's Online   0 Members, 0 Anonymous, 1446 Guests (See full list)
