the EX down under *4 15s walled in a Excel*
What kind of 6x9's are those?
G'day Kevin
The 6x9s are Cadence CVSL69 (below are some specs)
Power handling
  • 150 watts RMS each
  • 300 watts Total RMS
  • 300 watts peak each
  • 600 total peak watts
Features
  • 70 OZ Double stacked magnets!!!
  • 25 pound Speakers!!
  • 3-Way High Power Speaker System.
  • Stylized Chrome Yoke Plates.
  • Poly Emulsion Pulp Woofer Cones.
  • Butyl Rubber Woofer Surrounds.
  • 3” High Power Midrange Speakers.
  • 1” Neo Super Dome Tweeters.
  • External 3-Way X-over Networks.
  • Internal Mid/Tweeter Mylar
  • Capacitor Crossover Network
  • 2” High Temperature Voice Coil.
  • Double 70oz. Magnet Weight.
  • Custom Nickel Plated Speaker
  • cast aluminum frame
  • Connection Binding Posts.
  • Sold in pairs complete with all mounting hardware and grills
  • 4 Ohm
  • Frequency Response: 40 HZ - 20KHZ.
  • Sensitivity: 97 dB
  • Mounting Depth: 4.6"
  • Matt Black Chrome Finish
  • Butyl Rubber Surround
mentioned earlier I was on my way out the door to pick up an amp to run the 6x9s.
The 6x9s and amp cost total $215 which for Australia is very good.
specs are below.
Cadence F600-4
Specifications:
• 4 Ohm RMS Power: 125 Watts x 4
• 2 Ohm RMS Power: 175 Watts x 4
• 4 Ohm Bridged RMS Power: 350 Watts x 2
• PEAK Power: 1400 Watts
• Frequency Response: 10Hz – 40 kHz
• S/N Ratio: >100dB
• Damping Factor: >200 @ 100Hz
• Channel Separation: >65dB
• Minimum THD: <0.05%
• Input Voltage: 150mV – 5V
• Dimensions (L x W x H): 18" x 11" x 2.75"
Features:
• High Speed MosFET Power Supply
• Studio-Grade Bipolar Japanese Sanken Output Devices
• 3-Channel Mixed Mono Capable
• Fully Adjustable 12dB / Octave Crossovers
• Fully Adjustable Bass Equalizer
• Mute and Delay Soft Start System
• Full IC-Controlled Protection Circuitry
• Cool Blue LED Aircraft Style Illumination
• High-Level OEM Headunit Integration Harness
G'day
Well this is not so much an equipment update as it is just to show off my sexy new walls lol
Fired the system up this evening to find out where it peaks now with the changes we made but straight away there was a buzzing noise that could be heard through the door speakers :-/
On top of that somthing has happened between about three days ago and today because the 6x9s are not working (diffrent amp to the one running the front doors)......
If that all was not enough to turn a day bad it seems that the gains on the bonecrushers were "bumped" as the amps were out of the car so now the amps have to come back out again to set the gains lol....... in short we had zero time on the Termlad this evening.
I should have all of those problems sorted by the weekend or at the very least the bass will be sorted :D
This Sunday there is a dB Drag comp and car display at the local auto store so I will be getting some fresh footage and editing it up, there are some people just finishing up some interesting builds so there should be plenty of big bass! you can youtube search theexgotspl for my videos.
Anyway one bright note in a rather average day was getting the walls on my car as I mentioned.
They are 18s for those wondering.
  • 1 month later...
G'day
Been a while since my last update
Our last play around with the EX took us back a few steps and after some consideration we are back on the horse and things are full steam ahead.
(a couple of the designs tried and failed are shown below)
inner wall we tried using behind the flat baffle seen in previous pics = fail
4th order with port running behind the head = fail
different style flat baffle with a port down each side = fail
where it all ended up lol
The Vibe subs are out and will more then likely end up in the daily driver, we have ordered different better subs and they should be here by the end of next week. We are also redesigning the entire box and baffle design.
As we have everything out we will also be rewiring the entire system plus a couple of other bits will be cleaned up.
We have been using 0g wire untill now but earlier this week I picked up the cable below :)
15m length and the cable is 185mm2 or in other words it is HUGE....
G'day
Can't say to much before next month Kevin lol but I can say that we are looking at pushing past 160dB (no one in my state is doing that yet)
I can say though that the weird shape of the current box will be sorted out to make things easier and the baffle we use this time will be the 52mm MDF/Jarrah peice.
G'day
G'day
There is a comp at the end of the month I want to take the car to so rather then a last minute build we done a bit of work on Saturday, we are waiting for the subs to turn up so we decided to do somthing in the hatch.
We have moved the top amp down behind the bottom one so we can use shorter runs of power cable.
we took everything out of the hatch so we could take a look at things and decide what to do.
we decided to change the cabling as everything was out so had to drop the battery bank
this pic shows the fans mounted onto the mounting board of the front amp while the rear amp has kept it's perspex and fans in the same place.
here is a pic (taken on a phone) of the Earth wires ran, this cable is thick! but still looks very neat.
this pic shows a rough idea of how the hatch will end up looking, of course it will be neat and also there is a coupleof things still to be added to the hatch.
  • 1 month later...
Work has been going along slowly, we have changed from using the Vibe subs now to some 15" DD subs.
Here are a few update pics
52mm front wall being fitted up
some of the rewiring
mocking up the rear hatch
gone are the Vibes and in come the DDs
rear hatch close to done
