Is this enough net volume?
ehckz
If I build the box in the trunk I can get 7.7 gross volume, and after all displacements and a big slot port the netvolume drops down to about 5.7, or If I use 4 4" aeros i can get 6.5 netvolume.
Is 6.5 gross volume enough for 2 15"s (either going to be hdc3 or lvl 4s, im undecided at this point.)
Build In Progress for Slamology 2013
3 m1xl 18s walled in a gti
1 5k
4 batts
audio technix 1/0
8 cheap r/f 6.5s
mb quart 4.60
power is gonna make a difference.. but from my past experience the level 4's would like that enclosure better than the hd's..once again depending on how much power youre giving them...
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
at first 2400rms total......after I get my alt it will go up to 3500d or 3.5k
(depending on which subs I go with)
1 5k
4 batts
audio technix 1/0
8 cheap r/f 6.5s
mb quart 4.60
  • Who's Online   0 Members, 0 Anonymous, 1341 Guests (See full list)
