large gauge crimper
^ whoa. Crimping is that fast? A couple of years ago I was blow torching solder on my ring terminals and Knu 1/0 Flex wires it took about 15 minutes to do each one.
It's pretty much strip wire, put lug in crimper, put wire in lug, crimp and done.
Only takes a couple seconds :)
I spend more time hacking through welding cable with my set of dull 1980s wire cutters than I do on the actual crimp lol
I bought some chain cutters or something long ago from home depot and it snaps the 1/0 wire like cutting a string cheese with a scissor.
what dies are you guys using for say 4ga and 0ga? seems those are the most common sizes i will be using my crimper for.
NEUMAN
16sqmm die for 4 gauge
35 sqmm die for 0 gauge
NEUMAN
thanks. knew i could count on a washington guy to help out!
NEUMAN
I found a good cheap solution. You get a 10~25 dollar pair of bolt cutters, cut a knotch in the blade end to the crimp size.
the downside is you only get one size, but most ppl will just do 0 gauge anyway. I have the 16 ton hydraulic crimpers too though.
