What vehicle are you placing this box in?? and it will be beneficial to give me a couple of inches more, top or front if you want a less space saving design.
hatch type, non sealed off trunk, those are maxed out man. id rather knock off an inch or two from the height, and add one or two to the depth, but then the box would be possibly too close to the back.
All I would need is 0.75 extra to the top, if you want a center port back, 0.75 extra front to back, is that feasible?
So I modified my original post with the new spec, not sure if an all across bottom port is an option in your case, let me know.
Posted (edited)
yea id hate to say but these 15s dont fit, lol i cant go that high on height, i can do 17.75 with the double baffle, 36width and 25 depth. so im gonna do an 18or 12s
anything past 17.75 exceeds my trunk cover, thus i cant see out my back window very well at all
Edited by SlamminBeats
oooh your spec was messed up... yes you only would have 5-6 cubic feet after displacements.
yea, i mean it wasnt messed up, it would be hard to see out the back window, at that point might as well wall it, which im not doing, so its either the 2 9512s or 9518 sc. Which would work best? got any design for it? you should be able to work with my dimensions alot better for those.
