C.Sanchez.A Posted February 16, 2012 Report Posted February 16, 2012 I am once again redesigning a box for two Skar VVX-15s. I am very close to the box I am looking for. Here are the calculations using Torres Box Calculator Here is a skechup of the box NOTE: The bracing displacement is 2, because the angle of the baffle takes up 1.83 cubic feet of the box. The other .17 is for bracing and such. I will be hopefully running them off a AQ2200D, which will be mounted on the front, near the bottom. Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel
C.Sanchez.A Posted February 17, 2012 Author Report Posted February 17, 2012 Any one? Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel
Joe X Posted February 17, 2012 Report Posted February 17, 2012 Well two things, why didn't you use the Torres to calculate the volume, the lower fields are used for that, the other issue is that those aeros should have at least their diameter in front od them and should not be too near any walls to tune. Your port area / Vb is short and your net internal volume is a bit short of the minimum recommended. This box can certainly be improved with some changes and it woud be wise to recheck with the Torres your calculations for box volume.
Joe X Posted February 17, 2012 Report Posted February 17, 2012 Nothing seems seriously flawed though.
C.Sanchez.A Posted February 17, 2012 Author Report Posted February 17, 2012 Well two things, why didn't you use the Torres to calculate the volume, the lower fields are used for that, What do you mean? the other issue is that those aeros should have at least their diameter in front od them and should not be too near any walls to tune. This I know, the calculator just doesn't. lol. The recommended minimum internal space (after displacement) for these woofers is 2.5 each. Which I have, plus. What changes would you recommend? Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel
Joe X Posted February 20, 2012 Report Posted February 20, 2012 Thichen the top a bit to have the ports away from the wall and run the partially external if aesthetics is not a concern. Also repeat your calculations using the depth2 and height 2 fields to make sure everything is alright. Small stuff that maybe won't make much difference but you just probably wanted to know.
C.Sanchez.A Posted February 20, 2012 Author Report Posted February 20, 2012 The Height 2 and Depth 2 are for triangle shaped boxes. What I did was count the angled part as displacement. Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel
Joe X Posted February 20, 2012 Report Posted February 20, 2012 Check this out: Just saying, it could help you verify your calculations.
C.Sanchez.A Posted February 20, 2012 Author Report Posted February 20, 2012 True... Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel
