I can't for the life of me get the slide separated from the receiver lol.
I push the slide lock all the way down on both sides after I have slide pulled back a bit like my diagram shows yet it won't separate when I push forward. :( Any ideas of what I'm doing wrong?
Oh yeah, Glock 22 Gen 4.
Derp.
did you pull the mag out? if so and it still wont come off, lock the slide back. remove back plate and pull out the striker. then remove slide.
Yeah the mag is out lol.
Is it safe and advised to perform the procedure you said if I can't get it off?
Derp.
You just line the slide up and pull it back to put it back on..
You were dry firing it after you pulled the slide release down right??
I did per instructions to ensure it was unloaded. Bad idea?
Well if you were firing it to see if it was unloaded then yeah bad idea lol..
but to remove the slide pull the slide back, check that its unloaded push the slide release down and hold it down, now let the slide foward then pull the trigger all while holding the release down.. the slide should pop off..
  • Who's Online   1 Member, 0 Anonymous, 1660 Guests (See full list)
