How much SS to seal up the Stang?
Just make your baffle/beauty panel fit as tight as possible, then tape the seams. I wouldn't suggest much, if any, expanding foam in that car.
Yea, I won't be using any foam. don't want to add anything permanent to it like foam. For any mod that I've done to it I always try to do it in a way in which I can return the car back to stock/ original condition in the future if need be.
2003 Mach 1 Build
HU: Alpine CDA-9857
Sub: Fi Bl 4"VC fully loaded
Sub Amp: RF 1500-1bdcp
Highs Amp: Kicker KX650.4
Highs: Polk Audio db 6.5 comps
Epicenter
i misread, i thought you meant seal whole care and such with deadner
put blue painters tap on anything that the foam might touch and it will be 100% removable when you have to resell the car/return it to stock. when you seal off the trunk properly you won't need deadner for the trunk lid, because it won't be moving at all
  • Who's Online   0 Members, 0 Anonymous, 797 Guests (See full list)
