Hey guys, planning on doing a rebuild in the Mach 1, forward firing Fi BL 15. How much SS product would I need to for the trunk lid and to seal off the trunk from cabin? Thanks in advance!
2003 Mach 1 Build
HU: Alpine CDA-9857
Sub: Fi Bl 4"VC fully loaded
Sub Amp: RF 1500-1bdcp
Highs Amp: Kicker KX650.4
Highs: Polk Audio db 6.5 comps
Epicenter
if you seal it off properly then none for the trunk lid
so.. 10 at most?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Cool thanks guys. Btw it's an '03. So if I'm just going to seal it off what product should I go with, damplifier or DP?
2003 Mach 1 Build
HU: Alpine CDA-9857
Epicenter
Gorilla tape would be cheaper.
tis what i used
and btw you dont need it, but it takes 6 sq ft to cover the roof
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Ive used 75sqft for my small 4 door sedan, floor hasn't been touched yet. Thats 2 layers on every panel but floor so I'd imagine you are looking at 50-100sqft depending on layers and how much you can get on the outer door skin through the inner door skin holes
tis what i used
Gorilla tape? Really? How effective is that? I'm thinking of maybe getting a door pack to start to seal the rear deck and put some on the doors then go from there
2003 Mach 1 Build
HU: Alpine CDA-9857
Epicenter
