The shocks on my truck are shot and need to be replaced. I want to lower it, but don't know exactly what I need.
I also need to change the brakes but, I will get to that later.
Click Links To View Build Logs
1994 - Mazda B3000 (Daily/Toy/Show)
2002 - Mazda Protege (Daily)
1995 - Hyundai Accent (R.I.P.)
1984 - Bronco II (Restoration Project)
Youtube Channel
Not sure if the Mazda b3000 has the same front i-beam suspension as the 94' rangers but I had chassis tech lowered I beams on my 94 ranger and they were great. They gave me a 3" drop and ten I just flipped the axle in the back. (I don't remember adding blocks) DJM also had I beams that gave a 3"drop.
Here's a link to the ibeams for your truck:
http://www.airbagit.com/product-p/ibe-ma9497.htm
With these, it will maintain the stock ride and if you ever want to put airbags on it later on down the road you'll be ready cause you have to have these if you wanna lay frame.
  • 1 month later...
for the back you should have a spring over axel setup so you could lower the back with just some lifting blocks. that or google the ranger station and you should be able to find ideas on there
