Hooked up a buddys amp and sub combo he got from a friend. It is a older Kicker 850.2 and 2 kicker CVRs. Anyways they have the subs wired positive to positive and negative to negative on the subs. On the outside they got a wire from positive to negative and then one positive from the sub to the amp positive. And the negative on the outside to negative on the amp.
I don't know if this is correct or not. Don't know anything about bridging amps. I just hooked them back up the way they were. Is this the correct format for them?
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
I'm lost too. I don't understand how they have them wired... The voice coils are wired positive to positive and negative to negative. Then this random wire outside of the box goes from the positive to the negative on each sub.
Didn't get a change to take pictures. Needed to get the job done. They are dual 4 ohm. Now I didn't wire it like this just to clear it up. I just left it alone. I'm just trying to see why they got it like they do.
You gotta bridge this amp. I don't know how to bridge but it seems like it isn't bridge the way its setup.
Edited by Rebel4055
well they can only wire it to 1 ohm or 4 ohms (or 16 if they fail hard enough). i pray to god its 4 ohms, and that all the coils are in phase
