Help: Tapered T-line?
I've built a few t-lines for a single sub in the past. Currently Im trying to figure out what will fit and sound the best for my two DC 8 m2's. I love t-line but I can't seem to get two DC 8 m2's to fit on top of each other in my trunk (trying to keep the height around 14" tall by 34 wide, depth is workable). I've never built a t-line for dual subs... or a tapered tline. I've only built tradional t-lines for only a sigle sub. Can they subs be in the same chamber side by side (sharing the same line) or do they have to be seprate? How would I got about figureing out the taper? Any help would be appriciated. Heres the specs of the subs.
Mounting Depth
5.25"
Mounting Hole Diameter
7.25"
Motor Width
6.5"
Weight
17.5lbs
VC Diameter
2"
Displacement
.10³ ft
Sd
201.93 cm²
Vas
7.01 L
Cms
126.134 um/N
Mms
157.47 g
Fs
35.71 Hz
Bl
15.29
Re
3.95 ohm
Qms
4.64
Qes
.59
Xmax
16.5 mm
Sensitivity
79.04 dB
Edited by SojiaRaggs9000
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
if you look in the t-line sticky tou will notice a couple of dual sub t-lines, and they share the line. As for the taper, i think i saw one in the same section, and it was towards the end of the pages, so i would start at the last page and work back till i found it if i were you,
The Midget Looks Into Your Soul
2008 Dodge am 3500HD with the 6.7 Cummins
Race Me tuner, dpf deleted
kenwood double din
cheap walmart speakers for now(infinity reference comps comps coming soon)
2 kicker L5's in a ported box of unknown tuning lol(soon to be changed)
Power acoustic 1500.1 on the subs (for now)
If you use 1/2" MDF I believe you can get the height you need to get just over 16"s in your trunk. No clue on t-lines but I do know that. Think you can squeeze 17"s max in height.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
Maybe someone can explain to me how to figure out the taper?
No one? Is there some sort of equation that I don't know that helps in determining the taper?
U can't stack the design I have u?
u would loose 1 inch by combiningthe box's together! So instead of 11.5 it would be 20 ish, I think if u made the port 6inches wide, and 9 inches tall, then double that u would prolly be perfect
one sub above the the other
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
My problem is that I want the port and the subs firing into the cab. (I hate rattling trunks, imo think it sounds cheap). From the trunks floor to the bottem of the parcial shelf (closest to the back of the seats) is 14 inches. This is where Im running into trouble stacking the subs ontop of each other. Port wise I can fit it (doubled) no problem. But mounting the subs... eh I don't know.
You mean like this?
TEAM FLEX ISSUES, TEAM DC AUDIO
2010 California State Finals Champion MECA AS2
2011 California State Champion Meca S2
2011 California State Record holder Meca S2
2012 Meca Mod 4 class 152.5 and rising
Yes with the side-by-side configuration I don't have to worry about the 14" height problem. IF the side-side-side configuration is (ideal) ? What I really want to do is have the subs (over and under) on top of each other but with only 14" of height I'm kinda screwed.
So by going with the tapered type like you've shown in the picture... I can tell you started and ended the subs chamber and the end of the port with the same cubic inches. My question would be how did you decide what to reduce the port width down to. Just took 1/2 the SD? Or am I just making this out to be harder than it actually is haha...
Just personal experience by having the same car rear facing seems to be louder. Sealed forward sounded good but couldn't do over a 142 no matter what and that was a 12" XL on a DC3500. Now I have two 10s on 1k rear facing and it's just as loud if not louder. But yes rattles are annoying. Still working on dropping them. I know I've seen you just like tlines but I would try a 4th order ported through the rear deck angled with the back windshield.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
  • Who's Online   0 Members, 0 Anonymous, 2029 Guests (See full list)
