i have a hifonics brutus 1206d i believe it is but its 1200rms. i was reading on the net and it says if i turn the bass boost up that it goes to like 67hz or something. so i was wondering where the bass boost should be at. and also what exactly it does and why it raises the hz
Edited by ROBERT 04XBLZ
My New Build checklist:
(3) 18'' btl fully loaded d2
I personally believe bass boost ruins subs, I personally leave it off
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
a bass boost knob, is a distortion knob.
it adds db's to the signal centered around 45hz
if you play a note at 30hz its barely boosted along with something at 60, but around 45, which a lot of rap has that frequency is boosted but more than anything its boosted so much it produces a square wave a.k.a. distortion
unplug that thing, set volume @ 75%, no bass boost, flat eq, lpf @80-100, subsonic at ~25hz, and you shouldnt need any bass boost
if your system lacks bass either low, mid or high, it wont be corrected the right way by a bass knob
alright so no bass knob and the bass boost all the way down i cant turn it off it has a thing like for the gain that just turns . the knob that i have is for the gain though? is that the same thing?
I had that amp last yr, I used the bass knob and never hurt anything, just know your limits and you'll be fine
I also ran that amp @.5 ohms daily and had no issues ( i had good electical system behind it)
another question i have the subs wired parralel ++ -- ++-- then out to the amp ++-- the subs are dual 2 would that make it .5ohm
probably just a tad over 1200 watts @ .5 ohms, the amp does get warm like that, you just cant hammer it all day
  • Who's Online   0 Members, 0 Anonymous, 1044 Guests (See full list)
