i have a hifonics brutus 1206d i believe it is but its 1200rms. i was reading on the net and it says if i turn the bass boost up that it goes to like 67hz or something. so i was wondering where the bass boost should be at. and also what exactly it does and why it raises the hz
Edited by ROBERT 04XBLZ
My New Build checklist:
(3) 18'' btl fully loaded d2
a bass boost knob, is a distortion knob.
it adds db's to the signal centered around 45hz
if you play a note at 30hz its barely boosted along with something at 60, but around 45, which a lot of rap has that frequency is boosted but more than anything its boosted so much it produces a square wave a.k.a. distortion
unplug that thing, set volume @ 75%, no bass boost, flat eq, lpf @80-100, subsonic at ~25hz, and you shouldnt need any bass boost
if your system lacks bass either low, mid or high, it wont be corrected the right way by a bass knob
I had that amp last yr, I used the bass knob and never hurt anything, just know your limits and you'll be fine
I also ran that amp @.5 ohms daily and had no issues ( i had good electical system behind it)
  • Who's Online   1 Member, 0 Anonymous, 1274 Guests (See full list)
