Box design for 2 HDC315s
I recently decided to upgrade my system and get 2 AQ HDC315s running off an AQ2200D. I drive an 07 Trailblazer, I need a vented box design for them. The MOST room i have is 44"(W) 18"(H) 26"(D). I want it tuned around 34-35 Hertz. Someone help me out. Also, I cant decide whether to go with the 12s or 15s. Any advice on this? I think the 15s would have plenty of space, but ive never ran AQ before so im not really sure.. someone help me out please.
you would want 8-9cuft net, your max dimensions with 1 layer all around and a double baffle leaves you with 9.49cuft. each subs displ is roughly .25cuft. so you are down to 9cuft without even adding a port.
port would be roughly 130sqin give or take, to achieve 34/35hz tuning you are looking at over 1cuft port displacement
then you need bracing, which will take up another .1-.3cuft depending on what material you use
in other words, you dont have enough room
  • Who's Online   1 Member, 0 Anonymous, 396 Guests (See full list)
