BIG sub bandpass now n2 bandpass ray last question before i just build it!
CortezDTV
well you're not doing a 6th so you shouldn't.
i had a 3500 per nightshade @ .5 playing 22 hz damn near full tilt no subsonic filter and wasn't even close to 1/2 xmax. probably could have added quite a bit more power and i'd still have the same issue. anyways, that doesn't belong in this thread.
back on topic. 3 12s or 2 15s firing forward port going up so you don't have them firing into the port.
i think the sp4's are supposed to be good for 4ths.
hiiiiiiii
2002 4runner - buncha speakers n amps n shit (gone)
1994 astro - more stuffz
update: pretty sure all the pic links in the logs are broken lol.
ma slop garb build log
16 12's 4th order
4runner rebuild in progress
clickkk meeeee!!!! 4 18's 6th order
UBL - clicky
http://www.youtube.com/yyj11589
lots of hater kids here. Pay no attention, they just want 89,000 watt subs for 3.50
If you would have put a dc dustcap on it and called it lv your mom, they would all be in love
i think ur 6th order was built wrong ur subs shouldnt be restricted like that! sounds like not enough port area in one of the chambers
i would like to do a 4th order probably the best bet for a 150+ from the trunk if built properly
i cant fire forward you dont understand the layout of the trunk!
subs must fire down or towards each other with port towards the front of the car going forward onto/ under the back deck then up threw the back deck in a huge rectangle 7x22"
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
lol i got enough power and port to make a ground pounder!
PLEASE STICK TO TOPIC im not walling, im not changing the design of the box, only thing that might change is 2 subs facing eachother rather than one sub facing down or 3 subs facing down
mostly i want to know how the SMD, LVL 6, Crossfire V2, DDZ, Fi SP4, will proform in a bandpass..... mostly the bigger subs that can handle the power i have!!!!!!
SCSB
Build logs:
buy them, test them and find out. That is the only way to know what will work in your car, off the power you have and in the type of enclosure you have room for. Perhaps contacting some of the manufacturers you mentioned would be your best bet.
i take it you havent played with any of these subs......
im looking for real life input
ive talked to some of the manufactures but i wanted to see if anyone has tried a bp box with any of these subs
before i go waste a 5gs on testing subs! buy one and then a different, and another different
SCSB
Build logs:
mlstrass has 6 hdc4's doing 60's..
4 18's, low power and lots of gay fur.
Team gg
Team DOA
My Videos :)
ok so i got that the hdc4 will do 6th order, but im doing 4th, or wanted to, and it seems like under rms, or at least the potential of the sub
SCSB
Build logs:
  • Who's Online   0 Members, 0 Anonymous, 1198 Guests (See full list)
