Its a single flat piece of MDF:
Front to Back = 25 x 34 1/2
Parallel to the bottom wall, the bottom port needs bracing, if you would like me to submit ab updated sketchup showing optimizations and bracng, let me know.
Sure that would be awesome!!
So here are some basic suggestions, hope it helps:
Yeah that helps a million!!! Thanks alot for your help Joe X!! I just gotta upload the pixs to start my build thread!!
Ok so im cutting my wood up and trying to fit this monstrosity together and I see that the port is 25"dx34"w. Thats an awfully deep port! Is this right or is it a typo??
good luck on fitting that monstrosity in the trunk. You better deaden the fuck out of everything cause subs firing up in a trunk car flexes everything
Joo FAIL. Read before offering advice, OP bought a Bravada... :peepwall:
1999 Lincoln Town Car-(build underway)
- (2) SA15s, 4th order, DAT 2500.1, O2 mids n highs, 250a alt, HC 2400, Big 3....
1994 Pontiac T/A for speeding tickets.-
- Currently on jack stands, wanting to be a real race car
"Your local forecast, all the ladies in the metro area should expect to see 8 inches tonight" - The Todd
Decaf, on 01 November 2011 - 02:38 PM, said:
i provide the ammo for destruction, the trigger finger is connected to the volume knob tho
URBAN GORILLA AUDIO
Bump for help with this port issue !!!
