what do i want high and what do i want low? well what do i want more of? im new at the number thing i can do all the install but the db's and what not im really newb at. gimme some talk if you can
To Slide Sideways Or Not To Slide Sideways?
Head unit: Pioneer AVH-5000DVDSpeakers: 4 Pionner TS-G6842R Amplifier: Alpine MRD-300Subwoofers: 10" JL
SPL stands for SOUND PRESSURE LEVEL, DB stands for DECIBEL.
140 DB's are louder than 130 DB's.
LPF stands for LOW PASS FILTER.  If you have your LPF set to 80 hz then your sub will only play frequencies up to 80 hz.
HPF stands for HIGH PASS FILTER.  If you have your HPF set to 80 hz then yours speakers won't play any note under 80 hz.
These are amp features that allow dial in the exact range that you want your speakers to reproduce.
HZ stands for Hertz which is a measurement of frequency.
45 HZ is the bass note that usually makes your rearview mirror vibrate uncontrollaby, and say 12,000 hz would be a cymbal clash or a high hat IE a very high frequency note.
Any more questions?
so how does your lpf deal with db's? whats a good range for db's to lpf?
oh ya no its at lpf i just want to kinda ajust it to its full potentail
actually i just answered this on fullsizechevy.com. subsonic filter is awesome. it sets the lower frequency on the sub. a normal crossover on the amp means the sub wont play any notes higher than that. say u set the subsonic to 17 hz, the sub wont see any frequencies lower than 17 hz. its a great addition to any bassy guy who loves the lows ;)
thanks man now i get it!!!! :^
