So this is what i had to do!!
this box was built by me. i got it built put my subs in and it was tuned way to high. put the dimensions into torres for each side and it was 60hz. so since the box was done all i could do to it to get it to work was add a 3in wide piece to the port. so now the part of the port that goes back is 3in wide and the back L part of the port is 6in wide.(couldnt get behind it with the top on). not sure how to figure tuning now but it does better than the 60hz that it was.
most likely ill be building another box unless i can fix this one?
Any suggestions?
Edited by jeffrm
03 tahoe z71
4 death penalty 18s
2 ampere audio 3800s @ .5 each
18v
156.7 @ 35hz
158.5 @ 50hz
this is what everythings goin in. you dont see alot of trucks that look like this with camo on the inside
and i might use these dustcaps once everything is done
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
Can you extend the ports outside the box any? It looks like it's close to the back of your seats but that's the only thing I can think of
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
Well if you could extend the port outside the box then that would lower your tuning and depending on how far you can extend it then you should be able to take out those 3in spacers to give you more port area
And another idea is you could put something in the chamber (not port) to take up space and lowering box volume while staying the port dimensions the same should lower tuning frequency
So if I were you I would take out the spacers and extend the port then if it's not low enough still put something like a brick in the box
  • Who's Online   0 Members, 0 Anonymous, 545 Guests (See full list)
