This just recently started happening last week but the issue is that my passenger headlight doesn't always turn on, I have to get out and hit the headlight and it will light up. I haven't touched anything recently, I have to remove the whole headlamp assembly just to replace the damn bulb lol. I'm using PIAA Intense white bulbs, the are great and the person on the Cadillac forum who told me about them said he's been using his for the past 5 years and I only put mine in about year ago or so.
I just read that a headlight can fail if its subjected to a lot of vibration from rough roads, I do go over a lot of rough roads and that headlamp assembly is pretty loose due to some broken plastic that would hold it securely in place, new headlamp is $1000 =(
Edited by wonderbreadSTS
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
If you have to hit it to get it to light up it sounds like some loose contacts, either the wiring or inside the bulb. I'd double check that before I went and replaced the bulbs.
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
Ok yeah figured my light bulb wasn't already failing since its still bright when it does work, ahh hopefully its nothing too bad.
2015 Mazda 6
i had some PIAA's that had the same problem; that shit wouldn't turn on until i smacked the housing. i swapped in the factory bulb and it worked fine. before you get a new housing see if swapping the old bulbs back in makes a difference. might just be the bulb crapped out on you already.
don't got the old bulbs and yeah def not replacing the housing, its $1000 new and about $800 from the junkyard.
2015 Mazda 6
http://www.ebay.com/itm/CADILLAC-STS-99-00-01-02-03-04-RIGH-PASSENGER-SIDE-HEADLIGHT-HEADLAMP-GREAT-/280830019841?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item4162c60901
Theres one on ebay for 150 right now but its an auction.
92 Honda Prelude SI H23a3
HU: Alpine CDA-105
Front Stage: DB Drive PT6.0 6.5"
Rear Stage: Junk pioneers (Not sure what im wanting to do in the trunk, waiting)
Speaker Amp: DB Drive A4 4200
Sub Amp: MB Quart DSC1500.1
Subs: 2 12" MB Quart Premiums
Box: Slot port tuned to ~34hz
Wiring: Kicker Ultraflex 0awg and Big 3
Alt: Stock (saving for a 200amp Excessive Amperage)
Batteries: Optima Yellow Top and Stinger SPV44
Extra Equipment:
Two Rockford Fosgate T2 12's (Recones in future)
Kicker ZX1000.1
Selling:
I'll check out Ebay, hopefully its just the wiring a bit loose and can be fixed easily.
Did find a 2003 Cadillac Seville SLS though on Craiglist with 34k original miles for about $9k, might see about getting a loan from the credit union and getting that. So hey if anybody in Northern Cali is interested in a 99 STS for parts or to fix up a bit let me know, won't go more than $2k considering it needs suspension work among some other things but have replaced quite a bit since 2009 and it still runs like a champ. Despite what anybody says these cars are solid and the gas mileage is actually pretty damn good. Won't include my subs/amp but the speakers & maybe headunit will stay with the car which is in my sig. Just putting this out there in case anybody is interested.
2015 Mazda 6
