I been wanting to build my Box
And was wondering if u guys could help me out
Their going in an 02 grand Cherokee
My max dimensions are
width*42
Length *32
Height 29
I'm willing to pay as well
4 12 inch T3 audio
T.400
It doesn't matter
I just want what sounds best
Spec´s on the subs? T 3 is out of the market and the doin of this brand was hmmmm.....
"in the abundance of water, the fool is thirsty" Bob Marley
Specifications: *Power handling: 400 watts RMS/800 watts peak *VCdia: 2" *Le: 2.35 mH *Impedance: 4 ohms *Re: 4.25 ohms *Frequency response: 30-1,000 Hz *Fs: 33 Hz *SPL: 88.10 dB 1W/1m *Vas: 1.58 cu. ft. *Qms: 8.52 *Qes: 0.84 *Qts: 0.76 *Xmax: 16.5 mm *Dimensions: Outside diameter: 12.70", Cutout diameter: 11.15", Depth: 5.40".
Yeah I know Im getting a really great deal on them
And tought to my self maybe I should give them. A try
Or what do u think I shoUld do ?
I currently have 2 15 inch kicker cvrs
And it's just not enough
But then their in a prefab box
So here is a design suggestion for a ported box, subs firing upwards, port front or back centered:
Enclosure Specifications:
Fb = 32.026 Hz
Vb = 16.622 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 29 in
External Width = 42 in
External Depth = 32 in
Port Width = 8 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 42 x 32
Left & Right Sides = 30 1/2 x 26 3/4
Front & Back = 42 x 26 3/4
L Port Internal Assembly Parts:
2 x Front to Back = 17 x 26 3/4
Let me know any questions.
EDIT: Note that this is on your max dims but need to be at least 3 cuft per sub, seems to me that these are space wasters, I would probably look into other stuff also.
Edited by Joe X
Thanks alot man I'll take your word on that
I was doubting them for a minute as well so I guess I just won't get them
What would u recommend me to get in that case ?
nothing too crazy
I prefer something like 2 15s
Max 1000rms each
Problably nothing more than like 250 dollars each
300 if I really like them
I was looking into fi ssd's
