Mazda 323 small build. Pioneer 12's on 1k
It normally charges at idle fine. It's only after I've been bumping that it stops. I don't have a working rev counter so can't tell you the revs. But not many. Maybe 1.5k
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
Love the build man. Thought i'd pay your thread some love after you checked mine out ;).
Don't know if it will be the same problem, but i had "almost stalling at idle" problem with my previous car, was as simple as a loose connection on battery, so the sparks weren't firing properly. Check the connection and make it nice and tight if need be, and if it was like my problem that should sort it.
Honda Accord SirT + Mad sounds = Awesomeness
VTEC go BRAAAAAPPPP :P
http://www.stevemeadedesigns.com/board/topic/141261-99-accord-sirt-sq-build/
Alright well i never done the big 3 so i see in my vision my truck on fire...
thanks man, its not to bad for my first full attempt. i checked that first but it looks fine
PSN: Rcp_soundz
Definitely for your first build. Your second build will end up even better i can guarantee it.
Hmmm damn, well hope you work out what it is, but more so, hope it's not major.
  • 2 months later...
Might get out and take a video tomorrow, I haven't done much to the car laitly as im flat broke :L
PSN: Rcp_soundz
  • 2 months later...
Finally got some paint that isnt undercoat on my box!! looking good if you ask me
still needs one more coat
PSN: Rcp_soundz
Ive got to get a second coat on it anyway, so when i pull it next time ill finish it up nicer, I also want to redo the red, as its a little uneven as i sprayed it with a can that had next to nothing left lol, I literally only sprayed where you can see, 2mm outside that line and its primer lol
PSN: Rcp_soundz
