KHRISS Posted February 24, 2012 Author Report Posted February 24, 2012 can i use theseAutoVizion HID Kit Computer Warning Canceller & Anti Flicker (Twin Pack) HID Kit Wiring Harness CURRENT SYSTEM (VEHICLE) 2005 JEEP GRAND CHEROKEE (HEAD UNIT) KENWOOD KDC BT848U (DASHBOARD) INFINITY KAPPA 32.9CF (FRONT DOOR) JBL P693 (REAR DOOR) KENWOOD EXCELON KFC-X1730 (TWEETER) KICKER KS25 X 2 (SUB WOOFER) COMING SOON (4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP (1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2 (PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC (BATTERY) 1 OPTIMA YELLOW TOP (SIGNAL WIRES) KICKER XI (POWER CABLES) KICKER PKD1 (SPEAKER WIRE) KICKER 12 GAUGE (INTERIOR) DYNAMAT COMING SOON 2 FI SP4 18 COMING SOON 2 XS POWER XP3000 COMING SOON DC POWER 270XP ALT COMING SOON
audiofanaticz Posted February 24, 2012 Report Posted February 24, 2012 Why do people bother to post if they wont listen to advice givning and goto radio shack and get a couple of capacitors for $5 instead of spending $20-30 for the same thing in case and having to pay $10+ for S&H and wait for a product to show up, when things can be fixed for 1/8 the price and 10 minutes.... :fool:
KHRISS Posted February 24, 2012 Author Report Posted February 24, 2012 Why do people bother to post if they wont listen to advice givning and goto radio shack and get a couple of capacitors for $5 instead of spending $20-30 for the same thing in case and having to pay $10+ for S&H and wait for a product to show up, when things can be fixed for 1/8 the price and 10 minutes.... :fool: thanks for the info and i agree CURRENT SYSTEM (VEHICLE) 2005 JEEP GRAND CHEROKEE (HEAD UNIT) KENWOOD KDC BT848U (DASHBOARD) INFINITY KAPPA 32.9CF (FRONT DOOR) JBL P693 (REAR DOOR) KENWOOD EXCELON KFC-X1730 (TWEETER) KICKER KS25 X 2 (SUB WOOFER) COMING SOON (4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP (1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2 (PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC (BATTERY) 1 OPTIMA YELLOW TOP (SIGNAL WIRES) KICKER XI (POWER CABLES) KICKER PKD1 (SPEAKER WIRE) KICKER 12 GAUGE (INTERIOR) DYNAMAT COMING SOON 2 FI SP4 18 COMING SOON 2 XS POWER XP3000 COMING SOON DC POWER 270XP ALT COMING SOON
Hifonics Posted February 24, 2012 Report Posted February 24, 2012 Hey bud. Did you check your grounds? Flickering can be caused by a faulty ground. If you're going off the battery, get a wire brush and clean the terminals. If not, make sure you have a solid ground to the chasis/frame. Scrape the paint off of your ground or you will not have good contact (has to be bare metal). Hope this helps you... 2010 F150 FX4-18" AA Mayhem-Crescendo BC3500d-Pioneer GM-D9500F 4-channel-2 Crescendo FT1 -2 Crescendo Neo Forte 6.5 -Pioneer AVH-P3300BT-6000K HID Headlights/Fog lights-All LED interior lighting-20% tint on front windows, 1% rear windows, 5% windshield strip-Big3 (XSFlex 0ga) -DC Power 270XP -Group 65 NorthStar AGM battery Coming soon/plans: -Build log-Blacked out mirror reflectors-Tinted tails/3rd brake light
El1T3Bass Posted February 24, 2012 Report Posted February 24, 2012 Is this like a $20 ebay kit, or a reputable HID kit? i think its a wanna be relay kit reputable Basically the same thing lol Thanks for the cap mod tutorial! I'll be doing this tonight! wow now this just shows that smd isnt just any forum. We are a brother hood. here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now? Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
KHRISS Posted February 24, 2012 Author Report Posted February 24, 2012 Hey bud. Did you check your grounds? Flickering can be caused by a faulty ground. If you're going off the battery, get a wire brush and clean the terminals. If not, make sure you have a solid ground to the chasis/frame. Scrape the paint off of your ground or you will not have good contact (has to be bare metal). Hope this helps you... the stock headlights plug its connected to the error code eliminater then to the ballast the to the bulb CURRENT SYSTEM (VEHICLE) 2005 JEEP GRAND CHEROKEE (HEAD UNIT) KENWOOD KDC BT848U (DASHBOARD) INFINITY KAPPA 32.9CF (FRONT DOOR) JBL P693 (REAR DOOR) KENWOOD EXCELON KFC-X1730 (TWEETER) KICKER KS25 X 2 (SUB WOOFER) COMING SOON (4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP (1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2 (PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC (BATTERY) 1 OPTIMA YELLOW TOP (SIGNAL WIRES) KICKER XI (POWER CABLES) KICKER PKD1 (SPEAKER WIRE) KICKER 12 GAUGE (INTERIOR) DYNAMAT COMING SOON 2 FI SP4 18 COMING SOON 2 XS POWER XP3000 COMING SOON DC POWER 270XP ALT COMING SOON
Migz Posted February 25, 2012 Report Posted February 25, 2012 Most of the causes of flickering headlights are caused by the HID's using more power then standard bulbs in the warm up stage (as someone said before). They pull too much power for the stanard headlight wiring which can cause the headlights to flicker. All you need is a 12v relay, male/female spade connectors and a metre or two of cable. You just need to wire up the relay like this. 85 - Ground 30 - Power directly from battery (with fuse in line) 87 - Goes to the power cable of the HID bulb 86 - Goes to your stock headlight power wire. If you wire that up, then when you turn on your HID's instead of trying to pull too much power down the stock headlight cable and flickering as it doesn't get enough power, it will just get its power directly from the battery, giving it all the juice it needs. This needs to be done on ANY HID kit that doesn't already have it built in.
