just as the title states, i'm wondering how it would work with the front control arms and what not
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
well i have a 2 wheel drive so it wouldnt be too good offroad lol
To lower it to a fixed height would be easy, rear end, youd flip the leafs to the bottom of the axle tube, ( just like the Commanche aka MJ's came stock) ... for the front, get to cutting the coils or have a set of custom fabbed springs made up for your application. Grand Cherokkees look ok dropped, esp. if its an SRT, but the regular boxy Cherokees... not so much.
1999 Lincoln Town Car-(build underway)
- (2) SA15s, 4th order, DAT 2500.1, O2 mids n highs, 250a alt, HC 2400, Big 3....
1994 Pontiac T/A for speeding tickets.-
- Currently on jack stands, wanting to be a real race car
"Your local forecast, all the ladies in the metro area should expect to see 8 inches tonight" - The Todd
Decaf, on 01 November 2011 - 02:38 PM, said:
i provide the ammo for destruction, the trigger finger is connected to the volume knob tho
URBAN GORILLA AUDIO
thats a grand cherokee, i dont know how simular the suspension would be on it to a cherokee
..And depending on much you were to lower it, you might need adjustable control arms for the front to keep the wheels centered front to back in the wheel well opening, as the suspension on a Cherokee compresses it begins to push the front axle forward, adj control arms are an easy fix for that, as long as they can dial in short enough to do what you need.
URBAN GORILLA AUDIO
Since they are so commonly lifted, I'm sure you can consult any local shop about lowering it with professional advice.
lifting and lowering an XJ Cherokee are two completely different ball games.
URBAN GORILLA AUDIO
so from the sounds of it alot of custom made parts
^^ not at all. the rear pieces for the spring flip are factory jeep Commanche spring perches and a few minutes with a grinder and welder... the fronts, any commercially made adj. control arms from, say, rustys or rubicon express will do just fine, and the front springs? sawzall blades are cheap.
URBAN GORILLA AUDIO
  • Who's Online   0 Members, 0 Anonymous, 1633 Guests (See full list)
