i just got a new HU and with it a backup camera. the new HU sounds killer but if i wire the camera up, just the positive and negative to the battery, i get serious fuzzy static noises through my amped speakers. whether my decks off or not. what could cause this and more importantly, HOW CAN I FIX IT?
this is :bull:
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
what head unit what back up camera
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
hypnotic hdvd8700 and the rockshield or something like that. its straight to the positive of battery and ground to the car's body
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
Rockville RMC2 Easy Mount Night Vision Back-Up Camera
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
Try jumpering the ground from the cam to where you're grounded on the h/u
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
allright ill giv it a go in the morning.its 9 30 here now.
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
didnt work. is ther any sort of relay?
or if i get 2nd battery?
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
its probably the camera itself. im assuming as soona syou plug it into the screen you get it? how does it plug in? by RCA?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
yes single rca. i was thinking same way but if my cars on so amps are on, if i make connection to the positive with the camera it starts buzzing. is there anyway i could hook up a diode or something. think it could be power feeding back?i can get you any info you need i got the manual right here if you like. thank you for taking the time to help
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
