2 HDC3 15's with DUAL Vertical Kerf port
Just started this box tonight. Have about 3 hours into it. Just have to put the double baffle on, cut the holes, and it's done. Guy wanted it bare. Box is 7.3 cubes with 120 sq. in. of port tuned to 37 hz. Should make some boom in the back of his Trailblazer. On to the pictures.
how do plan to strenthen the kerfs?
1998 Monte Carlo Z34
Stock HU but have replacement
Stock Highs
Stock Electrical
BTL 18 sitting naked
AP1500D
Smothered in wood glue and might put resin on it. Wood glue is a lot stronger than a lot of people give it credit for. But if iy feels weak when i get off work then I'll resin it.
Not in a kerf, fiberglass it. There's not enough contact area for the glue to have any strength in the kerf and it makes a mess. In a year, you'll be glad you did. At minimum, put a 45 on the back side.
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
Ok. I'll be sure to put resin in then. I havent had a problem with any of my kerfs failing but nothing like extra support. Haha. This will eventually be seeing a lot of power so might as well do it well.
