Alpine Type X 12" Ported/Vented Box
HunterJohnson
Whats up SMD
Its time for me to upgrade from my SA-8 which I have thoroughly enjoyed in my Scion tC. I got a deal on an Alpine Type X 12" and I'm starting to figure out a box design. I want it to be ported, preferably a slot port and the sub will be in the box, I don't want it inverted.
What do you guys recommend?
Thanks!
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
What are the maximum dims of your box, how much power you intend to run and what car are you putting this on, with that info I can give you a design suggestion.
Thanks Joe X
Max Dimensions: L 15" W40" H12.5"
Power: Brutus 1200 which is 900RMS @ 2Ohms
If thats not enough I'll get the Brutus 2400 which is 1700RMS @ 2Ohms and I'll keep it turned down
I am putting it into a scion tC here is what the trunk looks like:
This is my setup right now, except I have a shuriken battery on the left side of the subwoofer.
Scion tC SQ Build
Ok so here is a suggestion for a single SWX1243 sub/port backfiring is standard configuration for that type of vehicle, can be changed later to sub/port upfiring if necessary but is not always recommended:
Enclosure Specifications:
Fb = 32 Hz
Vb = 1.3 ft^3
Subwoofer Mounting = Front Mounted
External Height = 13 in
External Width = 23 in
External Depth = 15 in
Port Width = 1 1/2 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 23 x 13
Left & Right Sides = 13 1/2 x 11 1/2
Top & Bottom = 23 x 13 1/2
L Port Internal Assembly Parts:
Front to Back = 12 x 11 1/2
Extension = 15 3/4 x 11 1/2
Went to 13H since the cutout is 10.9 and 1.5 is the thickness of the top and botton panels it gets rather tight at 12.5. Let me know any questions.
Right like your sa-8 box port sub backfiring
If you have 14.75H better follow this since is simpler to build:
Fb = 32 Hz
Vb = 1.303 ft^3
External Height = 14.75 in
External Width = 31.75 in
External Depth = 10.5 in
Cut List:
Front = 29 1/2 x 13 1/4
Back = 31 3/4 x 13 1/4
Left & Right Sides:
Side 1 = 9 x 13 1/4
Side 2 = 9 3/4 x 13 1/4
Top & Bottom = 31 3/4 x 10 1/2
Front to Back = 7 1/2 x 13 1/4
Extension = 25 1/4 x 13 1/4
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
