2 Amplifiers 1 Bass knob?
Amart88
Anybody know the best way to run 2 amps on one bass knob? I have 2 Hifonics BRZ2100.1D's and they each have their own bass knob. I don't want 2 knobs for obvious reasons. Will a splitter work for these amps? local audio shop mumbled somthing about their powered by the amps and all this other jarble that made no sense so I figured I would ask here for help, Thanks
Edited by Amart88
strap the amps. then connect the bass knob to the master amp and your good to go.
Noob question... How do i do this? master/slave? also there will be 1 woofer per amp. Never used these amps before or had 2 before so im a little confused with the process.
Get a pac lc1. Its a level knob that goes through rcas. Can use any amount of amps with it. A lot of people prefet it to knobs that come with amps. It's about 14 bucks
Yeah, I was considering the rca ones if nothing else would work.
watch this... it should help you out.
Thanks :) That video was quite helpful. From what I understand, I can strap my BRZ's together but I need them at 1 ohm and they will be at 2 strapped so I don't know if it would be the best option for this setup. I need to run each btl (dual-2) paralell at one ohm. Unless the 2 ohm rating strapped is each amp at one ohm together would = 2 ohms?
  • Who's Online   1 Member, 0 Anonymous, 625 Guests (See full list)
