help using my smd dd1
hi everyone i have a question i just got my smd dd-1 in the mail yesterday and i was gonna tune my system and i was reading threw the manual on what i need to do. and i have a question i am doing the measuring a head-unit through an amplifier and i see it tells me to set my eq and crossovers on the head unit and amp to flat but my problem is there no way i can set the eq and cross over on my deck to flat and i am not sure what to do.
head unit - eclipse cd5030
sub amp - plye drive plad 3300d
4 channel amp - rockford fosgate dsm4040
sub's - 2 12 inch sundown audio sa's dvc 2 ohm.
For the headunit just make sure the treb bass and if you have it sub vol to even
sorry let me make sure i got this right for my headunit i wanna set my bass and terb and my sub control on my deck to even.
Set them to zero - set everything to zero. Turn of bass boost, no bass eq - nothing.
Did you read the manual?
It tells you to turn the crossover all the way up
why cant you use it just through the rcas? i had that same problem, wasn't detecting signal so once i got to 1/2 volume it worked. easier then testing through the amp
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
plug rca into dd-1 find max volume. then use probs on the amp to find max gain on amp ?
  • Who's Online   1 Member, 0 Anonymous, 1988 Guests (See full list)
