free box designs with a sketchup pic or file
teardrop
Well i am planing on doing a build got my taxes. 2 SA 12 on a Sundown 1500v2. Dimensions 17(D) x15 (H) x 36 1/2 (L). Not sure about tuning. What is the average tuning? I want some nice hitting bass. I don't want to be just loud i want some nice quality if its possible. also forgot to add i want the port to be in the middle facing to the back. Subs facing back also thanks.
you dont have enuff space before displacement you only have 3.75 and need 4.0 at least
dying to do a sketchup right now... lol if you give me the box specs i'll draw it
lol if thats the case pm me and we can get started on another box! :twirl: and lets see what OP can do here... 2003 ext trailblazer 2 18" dc xls sundown 3k 46w x 38d x as high as you want.. looking for a box kinda like meade's with an interchangeable port...
wher do you perfer subs and port whats the displacment of subs
2 sundown SD-2 12s D4 wiring them to 1 ohm Amp Saz 1500v2 Max dimensions: don't really have but going in the back of an astro van So plenty Port Back subs back Subs specs : Fs: 38.8 Hz Re: 8.0 ohms Qms: 6.18 Qes: 0.69 Qts: 0.62 Cms: 0.09 mm/N Mms: 195 g BL: 23.5 NA Vas: 31.7 L Sens: 86.1 dB 1w/1m Le: 4.14 mH RMS: 500 watts Tune Hz: 33
i need diminsions
If you want to do one for 4 m1xls for my 2dr blazer I'd appreciate it, they'll be pushed by two 3.5ks at .7 ohms, they have upgraded spiders so they should be fine, the max width is around 38 inches, the height and length don't matter, I'm losing my back seat so I'll have alot of room, if you get bored I'd appreciate it!
i need sub info
2 18" blaupunkt subs 5400watts max 1800 watts rms going to be running at 1500rms want the box to be tuned to 30 to 35 hertz please struggling with the size help!
need max diminsions where you want subs and port and sub info
I've got 4 spl audio sp3 dual 2ohm 12's. 1000watt (Rms pair) I have 2 punch T 1500 amps if needed to power them. I'm looking for a wall with the port & subs facing forward . Max dimensions : 4ft wide 3ft tall & deep as needed. Thanks
need sub info
4 15 inch jlW0V2s :driver dis, 0.109,
Fs, 24.43 hz
Qes, 0.508
Qms, 9.474
Qts, 0.482
Vas, 5.106
Soundstream amp 2000 watts rms at 1 ohm
Max size 50" wide 16.5" deep 36" high
Think jl suggest 25 hz for tuning but I'm thinking 35 hz with the port on the drivers side. The box I came up with is 40" wide 38" high 16.5" deep with the port being 6" wide 30" high 25" long. This will be going in an s10 ext cab thanks!
current score-156.6 sealed on the dash
4 ZV3 15s
1 AB 1100.1
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
