free box designs with a sketchup pic or file
teardrop
subs make model: 4 sundown e8 v.2s specs:RE: 6.12 ohm Fs: 44.7 hz Qes: 0.5456 Qms: 3.6545 Qts: 0.4748 Le: 4.02 mH Vas: 7.26 L BL: 17.45 NA Cms: 131 uM/N Mms: 96 grams Sens: 82.59 1w/1m Xmax: 10.5mm one-way linear RMS: 200 watts ported cuft^3: .5-.6 displacement: .05 each cutout: 7.25 amps make and model: sundown 1500v.2 at 2 ohms max deminsions:37x14x36 subs and port direction: forward
i hade to do round ports but let me know if this will work its 2.45 cubic after dis tuned to 33 hz 10.26 in of port per cub ft and its double baffle
That might work. I have never messed with round ports. Could i use pvc pipe for ports? and also is there any bracing?
dying to do a sketchup right now... lol if you give me the box specs i'll draw it
lol if thats the case pm me and we can get started on another box! :twirl: and lets see what OP can do here... 2003 ext trailblazer 2 18" dc xls sundown 3k 46w x 38d x as high as you want.. looking for a box kinda like meade's with an interchangeable port...
wher do you perfer subs and port whats the displacment of subs
Subs up port back
wow now this just shows that smd isnt just any forum. We are a brother hood.
here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now?
Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
4 15 inch jlW0V2s :driver dis, 0.109,
Fs, 24.43 hz
Qes, 0.508
Qms, 9.474
Qts, 0.482
Vas, 5.106
Soundstream amp 2000 watts rms at 1 ohm
Max size 50" wide 16.5" deep 36" high
Think jl suggest 25 hz for tuning but I'm thinking 35 hz with the port on the drivers side. The box I came up with is 40" wide 38" high 16.5" deep with the port being 6" wide 30" high 25" long. This will be going in an s10 ext cab thanks!
you didnt have room for a slot port but you did for round this is tuned to 34 hz
Subs up port back
whats the sub displacement
i hade to do round ports but let me know if this will work its 2.45 cubic after dis tuned to 33 hz 10.26 in of port per cub ft and its double baffle chally1.jpg
no bracing pvc works just use a light sand paper on the ends to make smooth after cutting likea 600 grit
I've got 4 spl audio sp3 dual 2ohm 12's. 1000watt (Rms pair) I have 2 punch T 1500 amps if needed to power them. I'm looking for a wall with the port & subs facing forward . Max dimensions : 4ft wide 3ft tall & deep as needed. Thanks
need sub info
Nice thanks buddy that's awesome can those ports face the front so I can seal the wall off? Thanks again your a big help!
current score-156.6 sealed on the dash
4 ZV3 15s
1 AB 1100.1
I see the ports are 12.25" and the depth of the box is 16.5" so the ports will fit but will it affect the tuning but I can't wait to get started now looks sick.
4 ZV3 15s
1 AB 1100.1
4 spl audio sp3 12's (dual 2 ohm)
1000watt Rms(pair)
Max dimensions:
4ft wide
3ft tall
deep as needed
Sub specs:
Fs (hs): 26.3
Qms: 769.5
Vas (ft): 2.111
Xmax (mm): 13.25
Qes: 0.778
Bl : 13.05
Qts: 0.706
1000 Rms
2 Punch T1 1500's for power if needed
I'd like it in a wall. Port & speaker placement doesn't matter. Just want it loud, low, with good sound. It's going in a Yukon. Thx
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
